Adapting the overlap factor in OCM cycles
NC15012
Adapting the overlap factor in OCM cycles This tutorial shows how easily and quickly the control can process a change made to the overlap factor.
Prerequisites:
  • You have performed a test run of an existing NC program that contains OCM cycles programmed with an overlap factor of 0.25
  • You have changed the overlap factor to 0.5 in the cycle
  • You have repeated the test run
Video
Machine control Programming station Programming station VirtualBox Programming TNC 640 TNC 620 Tutorial
