3-D ruled surface, five-axis machining
NC4020
NC program for machining a 3-D ruled surface. With this program, the control uses the entries to calculate a simultaneous movement of all five axes so that an end mill can be used for machining. By using the TCPM function, the program is independent of the kinematics.
Supported by the iTNC 530 from NC software no.: 340 422-xx
TNC 640 TNC 620 iTNC 530 Milling in 5 axes (X, Y, Z + tilting axes) Milling Simultaneous machining NC program Programming station Programming station VirtualBox Machine control TNC7
