Horizontal cylinder, outside, as arc around X-Z with toroid cutter
NC7070
NC program for machining the outside of a cylinder surface with a toroid cutter. The cylinder axis is parallel to the Y axis. The machining operation is performed in a circular arc in the X/Z plane with the Z axis moving in the positive direction. The Y axis is the infeed axis.
Objects Milling in 3 axes (X, Y, Z) Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling Machine control Programming station Programming station VirtualBox NC program TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155
