Hemisphere, inside, in contour lines with ball-nose cutter
NC7105
NC program for machining the inside of a hemisphere with a ball-nose cutter. The machining operation is performed in contour lines so that the milling path runs in the X/Y plane and the infeed is in the X/Z plane.
Milling in 3 axes (X, Y, Z) Objects Milling Milling in 3 + 2 axes (X, Y, Z + inclined axes) Milling in 5 axes (X, Y, Z + tilting axes) Milling in 5 axes with turning function (X, Y, Z + tilting axes) NC program Programming station Programming station VirtualBox Machine control TNC 640 TNC 620 iTNC 530 TNC 320 TNC 426/430 TNC 415/425 TNC 410 TNC 407 TNC 355 TNC 310 TNC 155 TNC7
